Posted by Dean Meyers on February 12, 2008 at 16:59:00 from (216.228.196.109):
In Reply to: Re: Generator Trouble posted by John T on February 12, 2008 at 14:55:03:
Thanks John T. So, I went thru the troubleshooting guide from top to bottom. What is suppose to happen in step 4 when I take the armature terminal to ground? Nothing? The battery is good. Starts well and lights bright. In step 5 she goes to 30 amp discharge. Step 6 she goes 30 amp to discharge. Step 8 gen runs good and faster with field ungrounded. So I take the VR off to check the back terminal and it looks tight (GEN) terminal. Put VR back on and start her up. GUESS WHAT? She charges like a dream even with all the lights on.......has not done that in a long time. Guess its a bad ground on the VR. Will take it off again tomorrow and make sure I have good contact. THANKS JOHN T FOR THE HELP. I still cant figure why when I put jumper from the little ground wire on the VR to ground it did not work???? I am going to eventually put an Alternator on it. Tired of fooling with VR and GEN on my two Farmalls. Thanks again for the advice support and help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
