Re: Generator Trouble
Posted by Tom Windsor on February 12, 2008 at 17:43:18 from (64.12.116.73):
In Reply to: Generator Trouble posted by Dean Meyers on February 12, 2008 at 12:16:02:
Make sure the generator is grounded to the tractor. Clean the lugs on the generator and the attachment points on the tractor to make sjure of a solid ground.
tw
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
