I believe it's due to what I call cubic-inch-to-block-mass (CIBM) ratio.
The D361 has a low CIBM ratio, meaning the holes for the cylinders are fairly small compared to the size of the block.
You've got thermal mass there to soak up the heat and radiate it away in a controlled manner. There's more material in the block, which reduces its tendency to flex, twist, shrink, or grow under heavy loads and high temperatures (don't kid yourself, engine blocks DO twist and flex).
As soon as you start punching out the holes for more cubes, and clearancing the bottom end for longer strokes, you're removing valuable material that was making the block more durable.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
