Re: Starter dragging
Posted by Hugh MacKay on February 13, 2008 at 14:47:39 from (216.208.58.112):
In Reply to: Re: Starter dragging posted by Eds on February 13, 2008 at 13:55:53:
Eds: How cold are the temperatures where you live. If It's very cold and the seasonal disconnect is engaged, that will make it hard to crank. I had a 300 back when they were new always disconnected the PTO in winter. If I wanted to use the PTO in winter, I'd warn the tractor up then shut it off and engage the seasonal disconnect. That PTO turns hard when it's cold even with nothing wrong.
I'm not saying this will cure all, however it will let you know where the problem lies. If you disconnect it and it still cranks hard your quite well assured the starter is the problem.
