Dead grounding the gennys Field post makes it charge at its max capacity subject to any third brush adjustemnt n the gennys condition if its a 3 brush genny. However, if you have the lights on I doubt its gonna pump enough left over (after ignition if a coil system n lights) amps into the battery to overcharge it and/or outgas excessive or boil over acid in a period of up to a few hours or so. Its long times at fast RPM with no lights that a dead field grounded genny might possibly overcharge the battery and/or boil it over or outgas too badly.
If you have the LHBD light switch n 2 wire cutout relay system make sure the gennys FLD post is wired correct up to a good switch n that the switch is well grounded in the event she charges fine when dead grounded but NOT otherwise. However if you have a full fledged Voltage Regulator n it charges ONLY when you dead ground the field, the VR may be bad or its not grounded good or the wires bad from FLD on VR to gennys FLD post.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
