Re: IHC 1468 V8
Posted by ChrisAS on February 13, 2008 at 17:38:17 from (75.170.117.54):
In Reply to: IHC 1468 V8 posted by RIVIR on February 13, 2008 at 13:10:20:
Don't believe every thing that has been said so far,a straight DV550 will work right with a straight DT436 on less fuel. I did work for IH dealer at that that and we woild coustom plow with a 1468 and 5/18 plow no problem. The 4 / 8 was off governor and ran on all 8 at 75 percent.
I don't think the 4 were all on one bank, don't remember.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
