Re: Farmall B lights/genney
Posted by I forgot to tell you-Dave on February 13, 2008 at 18:57:24 from (205.188.116.73):
In Reply to: Farmall B lights/genney posted by jakey756 on February 13, 2008 at 15:05:31:
You need to check the ground to the lights including the "spring" that grounds the reflector to the case of the light. Dave
