Re: Farmall B lights/genney
Posted by Jim Becker on February 13, 2008 at 20:54:32 from (71.170.14.36):
In Reply to: Farmall B lights/genney posted by jakey756 on February 13, 2008 at 15:05:31:
The original system on a B was a cut-out type system. If everything is correct and working, when the lights are on the system will be in the high charge setting. In the high charge setting, the generator field is grounded (through the light switch but none the less a direct ground). Grounding it with a jumper at the generator simply hard wires it to high charge. If the rest of the system is working, you shouldn't see a difference in the head lights. It won't hurt anything if you are running with the lights on, and probably wouldn't with them off. Monitor the battery for signs of overcharging as John T described.
