Re: Working A Diesel Too Hard
Posted by Owen Aaland on February 14, 2008 at 02:24:14 from (65.165.246.161):
In Reply to: Working A Diesel Too Hard posted by skyharborcowboy on February 13, 2008 at 20:01:14:
The load should be such that the engine is able to maintain rated speed most of the time. This will be about 200 - 300 RPM less than high idle speed.
For gear drive F & I 656D the speeds are:
High idle - 2050
Rated speed - 1850
Minimum overload speed - 1500.
For Hydrostatic drive F & I 656D the speeds are:
High idle - 2580
Rated speed - 2300
Minimum overload speed - 1600.
There are no specifications given for exhaust temperatures.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
