Posted by Andrew Z on February 14, 2008 at 09:34:52 from (12.76.130.198):
In Reply to: Farmall H All Fuel?? posted by Arnettbros on February 14, 2008 at 09:14:51:
The little tank was for gasoline used when warming up the engine. When the engine was brought up to temp it was then switched manualy to either kero or distillate for the engine to run on for working.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
