Posted by Andy Motteberg on February 14, 2008 at 14:09:02 from (4.143.222.133):
In Reply to: Farmall H All Fuel?? posted by Arnettbros on February 14, 2008 at 09:14:51:
The small tank is the "starting tank", it was used on tractors that burn Distillate or Kerosene fuel. The small tank hold 1 gallon of Gasoline for starting the tractor, and then when you close the radiator shutter and let the engine warm up to the "RUN" in the temp gauge, you open the shutter and turn off the Gasoline and turn on the valve for the Distillate or Kerosene. Distillate or Kerosne was used because it was cheaper than Gasoline back then.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
