Pull the engine over & get #1 on TDC. Take the dist. cap off & see if the rotor is pointing to the #1 cylinder contact on the distributor cap. Should be very close. If it isn't, timing is probably off. If rotor is on #1 contact, look for moisture/ cracks in the dist. cap. Are wires solid or resistor? If resistor, check continuity with an ohmmeter. Bad wires will show high resistance[over 10,000 ohms].
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our
... [Read Article]
