Re: To dot, or not to dot, that is the question
Posted by Andrew Kappers on February 14, 2008 at 18:23:39 from (69.179.47.110):
In Reply to: To dot, or not to dot, that is the question posted by neblinc on February 11, 2008 at 09:58:16:
If your trying to make an authentic, original just rolled out the factory tractor you should use dot heads for shows but if your just going to use it for a work tractor, I would go with the new ones. Over the years the water soaked in and alot of the bolts from the deck cover were pitted and a lot of the dots got rubbed off from the operators feet. Up to you.
