The stress is on the bottom of the tractor. The load is pushing down trying to push the belly towards the ground.
Doesn't much matter how a guy builds 'em, just so it "strengthens" that bottom.
Old farmalls were really suspectable because of that big hollow torque tube, but I've seen 4020 JDs split right in half too.
After the problem started showing up, Farmhand changed the way they built the mounts so that the tractor was "beefed" as well.
Here's how I did my little H with the F-11. Also a picture of the newer F-10 mounts and then finally the F-235 mounts.
If you have a F-10 with the old "box" type mount, run a stringer from that box up to the front strut mount at the rail and pull it tight with a turnbuckle. Both sides.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
