Re: Why did the D361 last so long?
Posted by farm-al on February 14, 2008 at 20:00:00 from (66.43.192.234):
In Reply to: Why did the D361 last so long? posted by Kelly C on February 13, 2008 at 11:26:42:
I worked for a Detroit Diesel dist. for 32 years rebuilding engines and doing all the machine work on the blocks, we had a sk10 honing machine I used to honed out the 8.2 cyl bores to oversize,one IH mechanic used to press the sleeves into the361 block then bring it to me and I would hone the cylinders and tape fit the pistons, he always had good luck with rebuild life,the trouble with dry sleeves is the heat transfer can be a problem if the block bores aren't straight,thats why we usually rebored the 71 blocks and fit oversized OD liners,thanks,Al
