Darren: After looking at your tractor here are some of the problems and criteria we used in positioning cab on the 656. We hung cab from ceiling on chain blocks and backed the tractor under it, with fenders removed. The back window being too close to operator was not the only reason for choosing forward-rearward poistion. Had we moved it more forward it would have had to go 5" to clear and place the fuel cap inside the cab. I didn't want the fuel cap inside the cab.
Second was up or down position. We first thought of straightening the plarform where it rises at clutch and brake pedals, cutting a section out of those forward floor panels to allow the padals to come up through. Then positioning cab so door sills were level with the complete floor. Doing this would have required cutting portion out of cab cross member below the back window, so the 3 point hitch could raise to full height without striking cab. Problem with this lower position, some 3 point equipment I used were going to interfere with back of cab. Didn't really want to cut any material out of cab cross member. Then we hoisted cab so door sill was level with ends of floor where pedals make contact, hitch came up under cab cross member to just inside, view was still good all the way around as well as up and down. We fitted completely new mounts at rear between axle and cab, clamped around axle housing as opposed to bolting down like the fenders. For front cab mounts we used 1/2x3x3 angle iron coming out at an angle from the clutch housing. An upright bolted to housing, then a flat piece of angle went back at an angle to cab. We put a gusset in the angle of the two angle irons.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
