Re: pos or neg
Posted by El Toro on February 16, 2008 at 05:19:53 from (205.188.116.73):
In Reply to: pos or neg posted by buggsy on February 15, 2008 at 20:29:45:
If its a 6 volt battery its probably positive grounded. You should be able to tell by your battery cables. Since the pos terminal is larger
see if it is being used as the ground cable.
Those tractors were made when vehicles were changing from 6 to 12 volt systems. Post the number off the generator and look to see if the voltage is on there. Hal
