Re: Coil
Posted by Bob on February 16, 2008 at 08:47:46 from (69.178.229.154):
In Reply to: Re: Coil posted by ny bill on February 16, 2008 at 04:27:05:
The common way a starting bypass is set up is to run a run a wire from the "R" terminal on the starter solenoid (if so equipped) to the ignition switch side of the coil, so full battery voltage is sent to the coil while cranking, bypassing the ballast resistor.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
