Re: fireworks !
Posted by Bob on February 16, 2008 at 08:50:08 from (69.178.229.154):
In Reply to: Re: fireworks ! posted by Dave S. on February 16, 2008 at 04:36:48:
I agree EXCEPT for the fact that a system set up with a 6-Volt coil and ballast resistor AND a starting bypass WILL give a hotter spark during cranking than a "true" 12-Volt coil.
That is why the factory 12-Volt sysems were mostly set up that way.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
