Re: 8 volt battery
Posted by Tom43 on February 16, 2008 at 12:22:43 from (70.234.35.155):
In Reply to: 8 volt battery posted by N.D. Farmall H Puller on February 16, 2008 at 09:19:54:
8 volts will be hard on both the generator and regulator. On standard point type ignition,the increased current flow will burn points without a resistor added. Better ask the manufacturer before you burn up your electronic unit.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
