We used a ring gear from a Farmall M, on our belt pulley, and bolted a 560D starter to a plate, which we bolted to the frame rail, after aligning it with the ring gear. Our 14" belt pulley required a spacer ring, to make the ring gear fit. It takes some fabrication, but we are well pleased with the results. Really spins the Farmall over. We put a 7 inch pulley between the trany and the clutch housing, and mounted an alternator to the frame rail, right above the starter, with a belt between the two. We made a battery tray and mounted it to the other frame rail. Used a large 12 volt battery.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
