In Reply to: Re: Super M oversize kit posted by Scottys Super M on February 16, 2008 at 15:21:02:
The M 248ci. has to be bored if you want to run the sleeves for the 4.125" pistons. Some just pull the sleeves out, hone the block and run the pistons that way. I have a 1952 Super M with 4.125" 281ci. pistons in it.Pretty early tractor (7022J). It"s not running anymore but it there. I did pull the pistons out, they have 1" pins instead of the larger M pins. They simply put the thicker pin bushings in the rod. The sleeves look to be around .060 thick. So you"re not going to have any problems. Good Luck, Charles
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
