Re: F-20 HEISLER OVER-UNDER DRIVES???
Posted by BIG BORE 20 on February 16, 2008 at 16:10:59 from (12.192.31.234):
In Reply to: Re: F-20 HEISLER OVER-UNDER DRIVES??? posted by r4etired on February 16, 2008 at 14:59:18:
r4etired,
What you are calling a overdrive is what's known as a roadgear, Yes they run off the top shaft and the tractor must be in neutral for those to work. The overdrives ran on the main shaft this was just like the 9 speeds only the F-20 was 4 speeds so it double the main shaft speed before the trans. in overdrive. A over-under would give you 4 speeds under direct drive, 4 In direct drive, and 4 speeds in overdrive. for a total of 12 speeds forward. The ones I have are overdrives this gives me the 4 direct or standard gears plus 4 more in overdrive for a total of 8 speeds. In overdrive it doubles the main shaft speed and the PTO speed. My tractor had a fast 3rd gear 12.5 mph and when shifting into overdrive it put it at 25 mph.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
