Re: 8 volt battery
Posted by N.D. Farmall H Puller on February 16, 2008 at 17:02:53 from (69.178.202.105):
In Reply to: 8 volt battery posted by N.D. Farmall H Puller on February 16, 2008 at 09:19:54:
Mkirsck I do have the heavy cables and yes we do have a higher compression engine we have 3 9/19 in bore and with a 6 volt we can crank over easy enough but I think we lose enough volts that if the battery gets a little low the ignition does not want to fire like it should.
