Re: Pre Oil Rebuilt H?
Posted by Bob M on February 16, 2008 at 17:26:36 from (69.205.124.11):
In Reply to: Pre Oil Rebuilt H? posted by GordoSD on February 16, 2008 at 17:16:20:
Gordo - Here's what I'd do:
1 - Squirt an ounce or so of engine oil into each spark plug opening; leave the plugs out.
2 - Remove the rocker box and pour a half quart of so of engine oil over the rockers and valve stems. Now replace the rocker box.
3 - Use the starter to crank the engine (plugs still out...) until pressure shows on the oil pressure gage.
4 - Finally replace the plugs and fire her up. (If it's indoors now I'd suggest rolling it outside first - cause it's gonna make some smoke when it first lights!)
