Re: worn distributors
Posted by james rumph on February 17, 2008 at 04:48:14 from (24.192.116.205):
In Reply to: worn distributors posted by karl f on February 16, 2008 at 22:31:53:
Sure it would , if it is worn that bad that the point gap changes it will also effect the pickup coil gap as well . Watch when you take it apart, the length of the bolts that hold the points plate [inside] can"t change .
I put some new ones in that were alittle longer and they hit the plate that spins around the weights . It bent the plate and made a mess out of everything . Watch how you put it back together .
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
