Re: worn distributors
Posted by Janicholson on February 17, 2008 at 04:53:33 from (66.173.50.135):
In Reply to: worn distributors posted by karl f on February 16, 2008 at 22:31:53:
James R is correct. I'll add that the bushing can be replaced with one a little longer to ride on a portion of shaft that is not worn (if the one you have has more than .001 wear groove in it that should be done, or the shaft replaced. Make sure the springs and weights in the advance are good and operational. A dab of light moly grease between the two shafts is also good. JimN
