Re: Choke-issues
Posted by Janicholson on February 17, 2008 at 06:46:17 from (66.173.50.135):
In Reply to: Choke-issues posted by Kristof on February 17, 2008 at 06:27:40:
The Idle jet (or a combination of passages and jets)is plugged up in the carb. There could be low float level, but likely a jet. The adjusting screw is used to fine tune the fuel flowing through the main jet. The idle circuit is more than likely the primary issue. Buy a Carb Kit, a can of spray carb cleaner, and can of soak type carb cleaner to put the disassembled carb into. Then clean as recommended on the can, and blow through each passage with the carb spray. Be meticulous, and follow the directions. JimN
