Posted by tooltime on February 17, 2008 at 11:25:36 from (66.103.166.154):
the 12 volt coil i got from napa,its a IC14SB-NO EXTERNAL RESISTOR REQUIRED COIL. AND THE PLUGS I USED Were AUTOLITE #3116 DOES THIS ALL SOUND GOOD TO USE. ALSO I MAY NEED TO ADJUST TAPPETS I HEAR A BIT OF A TICK UP BY VALVE COVER, ANY SUGGESTIONS? ALSO THE 3 POST SELONOID MOUNTED ON THE STARTER MAY BE THE ONE THAT WAS ON THE TRACTOR WHEN IT WAS STILL A 6 VOLT SYSTEM, HOW CAN I CHECK THIS OUT? and should i replace it. it seems to work fine, does not get warm or anything. the coil gets a litttle warm, but not even close to hot. thanks for any input,Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
