Re: Cleaning a H carb
Posted by old on February 17, 2008 at 13:13:33 from (4.244.57.112):
In Reply to: Cleaning a H carb posted by Charlie M on February 17, 2008 at 11:32:29:
I use Berrymans chem-dip to soak my carbs in. A 1 gal. can of it with basket will cost you around $30. I then take the carb apart and put it in the basket and let it soak a day or so. then blow it out and srpay things out with spray carb cleaner. I also use a torch tip cleaner to make sure all passage ways are open and clean
