Re: H Idles High When Hot
Posted by Janicholson on February 17, 2008 at 14:40:17 from (66.173.50.91):
In Reply to: H Idles High When Hot posted by Tim O'Leary on February 17, 2008 at 14:20:02:
THe governor should be completely out of the picture when idling. If the idles speed screw, and idle mixture screw will not adjust the situation, It may be an air leak into the manifold at the carb, a crank into the manifold, or a gasket leak at the head surface. Another issue is possible worn throttle shaft bushings and shaft, allowing the plate to get stuck when the tractor is warmed up. Tapping on it might let it idle back down. If so it might need bushings put in the throttle, and maybe a shaft. Keep us informed. JimN
