Re: setting valve tappets correctly
Posted by hillbillyOH on February 17, 2008 at 16:49:36 from (67.142.130.26):
In Reply to: Re: setting valve tappets correctly posted by Janicholson on February 17, 2008 at 12:46:12:
I used a pipe wrench on the PTO shaft when I set the tappets on my Allis C. As long as you have the plugs out, you can make some pretty careful adjustments...
Just be sure to take the wrench off or disengage the PTO before trying to start her again. :)
