Re: Just bought a cab on ebay! $51
Posted by Hugh MacKay on February 18, 2008 at 02:40:15 from (216.208.58.187):
In Reply to: Just bought a cab on ebay! $51 posted by Darren In Pesotum on February 17, 2008 at 19:12:33:
Darren: Like me 33 years ago, I think you got a good buy, probably better than I did paying $500. for a new cab. At $51. it won't matter if you have elbo room, probably not so important as I thought earlier. I thought you operated the hoe from tractor platform.
You'll still run into same problems as I did, re; position of and distance from rear to fuel cap, plus the elevated floor at the pedals of the 656. The large chassis tractors have a flat floor, before cab. You will leave the fenders on, that's right, but I don't think it will change much. I think you'll find on 656 there are two positions for fender mount, you probably have to use the wide setting for that cab to sit between the fenders.
