Re: What Is The Reason?
Posted by Ronald on February 18, 2008 at 06:35:11 from (205.188.116.73):
In Reply to: Re: What Is The Reason? posted by Allan In NE on February 18, 2008 at 04:42:55:
I took the pump out of my H and stripped everything out of the inside of the tank(Shaft gears and case). But you'll have to plug the hole in the case where the shaft comes through. It gives a little extra room in there. I tapped the drain plug out to 3/4 and used it for the supply line to the pump.
Ronald
