Posted by Dave S. on February 18, 2008 at 20:39:54 from (204.96.145.190):
In Reply to: H Hour Meter Install? posted by Clarkbug on February 18, 2008 at 18:58:26:
I put one on my H with btry ignition and used the ignition switch and then went through a oil pressure switch to turn the hour meter on. This way the only way the meter runs is if the engine is running and not if the switch is left on.
The pressure switch is mounted under the hood just below the heat gauge on a brass T and cut the line going to the oil gauge then route it through the T. Mounted the hour meter just below the hood fastened to the gas tank mounting pedestal
