Re: IH's "standard" hydraulic cylinder for LiftAll
Posted by Jim Becker on February 19, 2008 at 07:23:05 from (71.170.14.36):
In Reply to: IH's "standard" hydraulic cylinder for LiftAll posted by Howard Junkin on February 18, 2008 at 17:56:29:
The original Lift-All cylinders were 2 1/4 and 3 diameters with an 8" stroke. Later on, a 1 3/4 cylinder came out. I think the 1 3/4 was common on cultivator rear sections as Steve described. These cylinders had the same basic configuration and were mostly interchangeable except for heavier equipment that required the larger cylinders.
The later 2-way cylinders like Allan pictured were made in 3 1/2 diameter and later in 2 1/2, both with 8" stroke.
