Posted by bruce omn on February 19, 2008 at 09:01:28 from (148.150.30.3):
Hi all,
Just for the record, my 460 couldn't dive in a snowpile with out sputtering and dying.
I've improved my worn distributor, spruced up the rest of ignition and electrical, checked valve lash, clean carb, still sputtered when it the governor kicked in.
Then in the TLC process I noticed the hand throttle linkage was loose so I built up some of the worn connections. Finally I saw the long rod from the control panel to the governor was bent and binding on the rod from governor to carb. I rebent them to give them clearance.
Finally we got a modest snow in east central MN, enough to clear the driveway. After a couple hesitant governor actions, it started limbering up. After a half hour of getting to work the way it should, that governor and engine were a delight to work with.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
