Posted by Janicholson on February 19, 2008 at 09:36:30 from (199.17.6.122):
In Reply to: cluch adjusstment posted by bigfutty on February 19, 2008 at 06:48:20:
Adjust the clevice on the clutch rod (heat might be needed if it is stuck). The adjustment is very close to 1" at the point the pedal touches the deck when your foot is off of it, to the point of first contact with the throwout bearing. Hand pressure feel of contact is fine, no need to be looking at it. If it misses when under a modest load (assuming that is what you mean above ) try adjusting the main jet a little richer to allow better operation. Marginal sparkplugs and or wires can also cause mis-under load. as can vacuum leaks, and other factors. Tell us more about the misfire. Evenly one cylinder, any at any time rough running, or just putting the lever in gear causes it!! JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
