Re: WHERE DOES IT GO???
Posted by r4etired on February 19, 2008 at 14:27:38 from (166.145.185.164):
In Reply to: WHERE DOES IT GO??? posted by JFAVOR on February 19, 2008 at 07:37:21:
I believe the bolt that holds the pilot bearing in the top shaft is a fine thread. the washer sure looks right though.
