Re: WHERE DOES IT GO???
Posted by rd/oh on February 19, 2008 at 16:54:15 from (65.17.134.126):
In Reply to: WHERE DOES IT GO??? posted by JFAVOR on February 19, 2008 at 07:37:21:
this is not tractor but is old Years ago mom had a '41 plymouth. rod bearing went out and I backed it in the barn and had at it. when I got it back together I could not fint the drain plug. I found a spark plug that fit. some months later the bearing went out again. when i tore it down again I found the plug laying on theframe flange. did not need the spark plug any longer
I was 16 then and almost 74 now
