Re: WHERE DOES IT GO???
Posted by JFavor on February 19, 2008 at 19:53:08 from (205.188.116.73):
In Reply to: WHERE DOES IT GO??? posted by JFAVOR on February 19, 2008 at 07:37:21:
Thanks D Slator. You're right. I can just pull the input shaft out. Hadn't thought of that. Yes, the corners are rounded where it fits in the washer.
That won't be too big a deal. I can just slide the drive shaft forward and remove the shaft. Thanks again. Jim
