Re: IH 886 front wheel wobble
Posted by Brownie450 on February 20, 2008 at 11:49:16 from (216.51.158.220):
In Reply to: IH 886 front wheel wobble posted by Dirt Digger on February 20, 2008 at 09:37:48:
While tractor is stationary, turn the steering wheel back & forth & look at the top of the left spindle to see if there is play between the arm & the spindle nut. If there is play here, it could be loose splines at the top of the spindle or bushings as mentioned before. A third possibility is a worn-out thrust bearing which is at the bottom of the spindle where the axle hub is located.
If this area is satisfactory, jack the left side of the front axle up & check the wheel bearings with no load on them. Have you checked the tie rods???
