Re: A is stuck
Posted by old on February 20, 2008 at 14:08:36 from (4.245.2.248):
In Reply to: A is stuck posted by HicksDale on February 20, 2008 at 12:48:56:
Well if it has anti freeze or water in any of the cylinders pouring in the ATF will not help. I would pull the plugs and make sure its not a hyd. lock. If it isn't then you need to blow out or wick out the cylinders before doing the ATF or you will get no where with it. May need to pull the head off to see whats wrong since you see anti freeze on the side of it
