Re: 3 point vs Draft control
Posted by Allan In NE on February 20, 2008 at 15:08:39 from (148.78.243.25):
In Reply to: 3 point vs Draft control posted by Mike560 on February 20, 2008 at 14:35:54:
What Bob said.
Draft doesn't mean sic-'em unless you are tied to an under soil implement, which is mounted to the 3-point; then they really shine.
Hydraulic system senses so quick that you don't even know it's happening. Tractor just pulls at a good steady load.
Allan
