Re: 3 point vs Draft control
Posted by Hugh MacKay on February 20, 2008 at 15:19:40 from (209.226.247.131):
In Reply to: 3 point vs Draft control posted by Mike560 on February 20, 2008 at 14:35:54:
Mike: Most tractors equipped with factory 3 point hitches have automatic draft control, and do exactly as Bob describes. After market 3 point hitches that have been added to old tractors that never had 3 point hitch do not have automatic draft control. These after market firms are selling new 3 point hitches for around $1,000. Automatic draft control would probably add $4,000. to that price tag. If you look at the modern day 150 hp tractor that automatic draft controlled hitch on the back probably represents 10% of the cost of the tractor, yes it probably exceeds $10,000. No one is going to spend that kind of bucks on a Farmall H or M.
