Re: M DRAWBAR ON H?
Posted by Janicholson on February 21, 2008 at 05:16:20 from (72.25.161.218):
In Reply to: M DRAWBAR ON H? posted by LOUH on February 20, 2008 at 13:30:44:
Jed and CNKS are correct on the bar. I would think (just thinking) thay the M bar could be reduced in thickness where it inters the belly casting to allow use. Another Wild idea might be to use the M belly casting and pin. I do not know if the bolt spacing to the trans casting is the same. A drawbar is much easier to turn with when pulling heavy pull implements that aren't lifted at the ends of the field. Welding up your old one is certainly possible. JimN
