Are you guys using the CHAR-LYNN pump for your loaders as thats what i have on a loader i built for the B. I made it like the new stuff so i pull two pins ans the two on the cycls and the boom is off. I made a blade to push snow works fine. I have another B with the same pump and have a three pt blade on the back just use a two-way cycl for the center link and only use one side to pic up as down pressure just causes a traction problem.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
