Re: OT: IH 60 plow lift height
Posted by LMack on February 21, 2008 at 17:55:28 from (68.157.139.93):
In Reply to: OT: IH 60 plow lift height posted by mkirsch on February 21, 2008 at 10:07:44:
The plow should be level with the furrow wheel in the furrow. If there has been a lot of welding etc on the land axle, you may have a problem. I suspect that the axle was heated to straighten at some point. If so, the metal hardness and rigidity has been damaged. If you can replace the weak axle you will do better. If it is possible to heat and quench the axle several times, the siffness may be regained, however it would have to be removed from the plow. You have to heat it cherry red and quench it quickly in water to restore hardness (several times). As you can see, this is not something you can do with a torch. This is a machine shop job. Heating the steel and then alowing it to air cool with certainly cause soft steel to form.
