Re: OT: IH 60 plow lift height
Posted by mkirsch on February 22, 2008 at 06:26:10 from (64.80.108.53):
In Reply to: OT: IH 60 plow lift height posted by Andrew Z on February 21, 2008 at 10:07:44:
Maybe I'm okay, then. If it should be level with the furrow wheel in the furrow, I can do that by adjusting the depth lever to drop the right side of the plow several inches.
The plow sits about level on level ground with the right side raised as high as it will go.
I don't think the axle has been heat damaged. The lift arms that are welded to it were torn off at some point, and welded back on. That axle appears to be solid steel, and I'm sure it'd take a lot more heat than that axle's seen to soften that much steel. The paint wasn't even burned off.
What I'm trying to determine here is whether I can just clean things up and reinforce the arms with additional flat stock, or if I have to cut the arms off and start over.
Thank you for the additional information!
