Re: Right Sequence
Posted by oldiron29 on March 11, 2009 at 16:43:18 from (69.112.215.121):
In Reply to: Right Sequence posted by Farmall Bob on March 11, 2009 at 16:18:42:
Bob, you have 3 pt hitch correct. so a 2 point will not work without changing the hitch.
A 2 way plow has a mounted frame will not work with 3 point you will have to remove hitch.
So least amount of work would be 3 point hitch 2 bottom plow. oldiron29
